Just greasing the 32 and can't figure how to do the lower spindle king pin fitting. I have the original style fittings and the tip of the gun will not maneuver in that tight spot. I was wondering if a new style 45 or 90 degree fitting might fit and allow enough room. Thanks
1932 5 Window Confederate Coupe Best of Era 6 cylinder 2016 1968 Corvette Roadster 383 CI-425 HP 1938 Business Coupe "personalized"
The passenger side fitting should be straight but I find turning the steering wheel all the way left allows easy access from behind the wheel. The driver side is a 45 degree fitting. I am pretty sure no judge would notice if you put 45's on both sides to make it easier. I do have some 45 Alemite if you decide to go that way.
Quite often turning the wheel all the way to the right and/or left will expose grease fittings otherwise inaccessible, with no other changes necessary.
I have a few of those myself, the worst being a drag link on a '52 Ford truck.
It's a bit of a pain to do, but maintains the originality of your car.
