#41028 04/29/03 10:57 AM
I have a 350 small block pretty much stock except for a larger cam .510 lift, 275 heads that have not been ported or polished, double springs, and high performance lifters that came with the Blue Racer Cam and I am using a edelbrock 750 carb.
____________________________________
The cam has a .510 lift. I also have a MSD Ignition kit installed. And the fuel pressure is only at 4psi with a quadra jet carb, it isn't the carb., because the quadra jet carb., is in replacement to the Eld. 750 that is brand new I just took it off to see if it was the problem, still too much fuel is going to the plugs and out the exaust, the #2 and #3 plug seem to foul first the heads are stock and so is the motor it is a 4 bolt main, I don't know what to do with it?
Any help will be appreciated!
68 camaro over 4 years in the making.
Wilwood Engineering1955-1957
#41029 04/29/03 09:12 PM
Are you useing stock or after market intake? and is it exhaust heated or cold? A single plane after market on a stock engine will dump gas at low rpm as will a manifold with to large or too long runners.A heated carb will work better.
ok
woody
#41030 04/30/03 08:05 AM
I am using an aftermarket edelbrock intake! Not sure about the exaust heated or cold, what is the best way to check? Just feel what is coming out?
#41031 04/30/03 08:31 AM
There are ports in the head that let exhaust gas into the manifold ,it runs to base of carb.base of carb chould be hot after motor has run for a while.If you have stock exhaust manifolds make sure the heat riser is working.also make sure your choke is opening.
woody
#41032 04/30/03 08:44 AM
I have hooker headers that run into a 2.5 inch flowmaster exaust system.
#41033 04/30/03 08:54 AM
#41034 04/30/03 06:20 PM
If that Edelbrock is a single plane with that cam it will not run right under 4000 or so rpm even with a two plane that is way to much cam for good street driveing .I have the old 350 horse 350 cu. cam with an Edelbrock Perfomer manifold with a rebuilt quarajet. on a otherwise stock 350 in my 80 Monte Carlo with a350 automatic and it runs like a dream ,has for the last10 or more years .Rethink the cam and check your manifold and you should be in good shape. Good luck.
woody
#41035 05/01/03 08:26 AM
Thanks, that is exactly what I intend to do, starting this weekend.
Thanks alot for your help.
