Plugs Foul/Gas in Exaust - 04/29/03 02:57 PM
I have a 350 small block pretty much stock except for a larger cam .510 lift, 275 heads that have not been ported or polished, double springs, and high performance lifters that came with the Blue Racer Cam and I am using a edelbrock 750 carb.
____________________________________
The cam has a .510 lift. I also have a MSD Ignition kit installed. And the fuel pressure is only at 4psi with a quadra jet carb, it isn't the carb., because the quadra jet carb., is in replacement to the Eld. 750 that is brand new I just took it off to see if it was the problem, still too much fuel is going to the plugs and out the exaust, the #2 and #3 plug seem to foul first the heads are stock and so is the motor it is a 4 bolt main, I don't know what to do with it?
Any help will be appreciated!
