Page 1 of 3 1 2 3
#266399 01/02/13 06:21 PM
Hello,
first a happy new year to all rockband
Today I worked a bit on my Chevy and opened the transmission, to see why it always scratches when changing gears.
Can you even look at the pictures and tell me if the gears are in good condition? I think the 1st gear flanks are very rounded? I also found some metal shavings, I think copper? Can that be from the Synchronizer Rings? Thanks for help.
Greetings André
1940 Special de Luxe Sport Sedan
https://1940specialdeluxe.wordpress.com
Have you checked the adjustment for your vacuum shift unit?
No, not yet. I must do this too, but my brother in law - the previous owner - means that some gears were worn-out. Now i would check this with a look inside. Upshift scratches almost allways, downshift is better. I´ve tested with a longer break between shifting, with gas between, fast, slow - nothing?!
Greetings André
Are you using a high viscosity lube? SAE 160 or 600W are thick like molasses or cool honey. The high viscosity lube helps to synchronize the gear speeds.
It was common for cars with the vacuum shift to wear out the syncronizers. This was because the vacuum assist would change the gears with more force than a manual linkage would. The most common problem would be grinding of the gears when shifting from 2nd to 3rd gear. Years ago we just replaced the complete syncronizer drum. They are almost impossible to find today and very expensive.
Gear wear. If the edges or tips of the gear are worn or chipped a little it will not cause a problem. The wear that can cause excessive gear noise is when the tooth contact area is worn or rough. Also if the bushings in the cluster gear are worn....brass bushings.
@ chipper - My Brother in Law filled in SAE 90?!
@ chevynut - thanks for this information. I think for a better diagnosis i must disassemble the Transmission.
With Synchroniser drum you mean Syncro and Sliding Clutch ? On this side they have also Transmission Synchronizer Rings
Is it possible to restore the drum? Hmm,brass bushings? I think there are copper shavings?!
Greetings André
Today i took a second look. what i see makes me not happy.
I think the countershaft gear and the 1st gear / reverse gear shows strong traces of pitting. These metal shavings on the first picture look a lot like brass!
So Chev Nut is quit well and the bushings in the cluster gear are worn. The shavings it has crushed between the gears.
Can you tell me what parts i must get for repair? As example on this side www.vapinc.comi need:
WT242-8 / WT242-12 / WT242-50B Small Parts Kits, what would be even advisable? WT242-18 Synchronizer Rings?
Greetings André
I can't see all the gears that well but as far as the gears go it looks like you will need a cluster gear and shaft, First and reverse gear and 2nd speed gear. If the gear on the front shaft is bad you will also then need a main drive gear. And of course a syncronizing drum.
These parts fit from 1940-1952 for the most part .
Hallo André, da bist Du ja mitten drin in der Materie. Wenn ich etwas Zeit hab, schreib ich Dir ne email, ok?
Viele Grüsse
Stefan
Hallo Stefan,
ein gutes neues. Ja gerne, hab diese Woche noch Urlaub und Bock auf Schrauben gehabt. Aber mit diesen Teile katalogen verzweifele ich noch.
Gruß André
Greetings André
i was lucky enough to drink Goot German BIER in Munich ! XCELLENT - makes me thirsty ! : )
You mean i need the 2nd speed gear, too? Seems to be o.k.? The link in the posting above shows more detailed pictures.
[Linked Image from img40.imageshack.us]
Where can i get the right Numbers for my Parts? My Master Parts List 29-40 has not all numbers. I am missing Numbers i´ve found on my gear box at example yoke 591039 and cover 591026. Do i need the complete drum ore only the rings? Have you a idea where to get the parts?
Greetings André
I will get back to you this evening with part numbers.
Oh, that is very nice. Thanks a lot.
Greetings André
Cluster gear
591074 -
fits 1940-1953 - has the brass bushings like the original
591319 - roller bearing type, Would require proper shaft, needle bearings and thrust washers
3845201 - later replacement, comes with roller bearings, shaft and thrust washers. Fits 1940-1957.(best choice and may be easy to find.
first and reverse gear
591088 - fits 1940-1953
syncronizer drum complete
605020 fits 1940-1952
main drive gear (front shaft)
609741 - fits 1940-1952
second speed gear
591078 - fits 1940-1952
The front and rear ball bearings should also be replaced. available in modern
Good morning everybody.
For me I guess the 1st question to be answered should be: Does a 1940 RHD car have the same tranny as a 1940 LHD car? I have never seen a RHD 1940 and dont know how the gearshift mechanism is transfered to the other side...
Stefangermany
German beer? good, yes, indeed, but 1st bavarian beer (Munich) is better and 2nd actually I want to reduce my beer tank inside (belly) and dont drink beer...bad...but a MUST.
Hi Chev Nut, many thanks for help. Now we seemy Problem. No one from your numbers i can find in my Master Parts Price list 29-40? Do i need a PART INTERCHANGE List? Or another Part List? Filling has many, but wich one is the right one?
CD´s DG-63,DG-64,DG-174,DG-175 or Books FS-21 DG-173 DG-91?
I own too, the Shop Manual 1940 and Fisher Body Manual 39/40. Sorry for so much questions, but i´m very unsettled.
When i go to Obsolete and type in 3845201 they bring me "Xref" this Numbers
Competitor 266-8
Competitor 3817960
Competitor 3845001
Competitor 3845051
Competitor 3845201
Competitor 591319 according to your discription it is not the same as 3845201 i think?
Competitor K331-11
Competitor WT-242-8A
Competitor WT242-8A
please
@ Stefan - the tranny seams to be the same. The Shift Linkage is on the same side - Left!
Greetings André
These are the numbers from my parts catalog
Cluster gear, this is Countershaft gear, right?
591106 (w/bushings)- Group 4421
591113 - Group 4417
591082 - Group 4380
591081 - Group 4403
second speed gear
591110 - Group 4395
Greetings André
Cluster gear is the the same as the counter gear.
The numbers canged from what was printed in 1940. You will have a much better chance of finding the parts with the numbers I gave you as these were the last numbers used and were around for over 50 years,
I don't know about the case but the side cover was on the left side for the US cars. That is the side the exhaust is on and what we call the drivers side.
I beleive that I have New Old Stock second gear and a first + reverse gear.
If that is any help E-mail me at; bwbugay@aol.com
With the RHD column shift cars I have seen the shift rods still connect on the left siode of the box but there is an extra set of linkages to connect that cross under the bell housing / gearbox joint, manual and automatic. More moving joints to wear and cause trouble.
Hi,
yes the side cover and the exhaust is on the left side too. I wonder that there are no buschings in the part lists, only on the 4 Speed transmissions?
Greetings André
Andre,
Used 1940 complete transmission. See photo. I have not opened it up for inspection but will do so if desired. Weight 48 pounds as is.
I can remove externals if desired to lessen weight. Your call. I don't want to tear it apart though, i.e., take the gears out of the case.
If you can use it, it's free (to you.) No charge. You merely pay the shipping only which you will have to arrange.
Best wishes,
Note to monitor: Please excuse the "blah, blah." I'm merely trying to help a fellow member. I hope that's okay.
[img:center]http://[/img] [img:center]http://[Linked Image from i753.photobucket.com][/img]
Charlie , what's that second transmission doin ? sniffen or sumthin ? frank
Page 1 of 3 1 2 3
