Well I returned the kit I purchased from eBay and purchased new uppers and lowers from chevsofthe40s.
Guess what. Same problem with the uppers. The bushing wont even start to thread into the upper A arm.
(The old bushing hand screws in with no problem.)
I had a machinest look at the old and new bushings.
Old bushing: .979-OD .957-root thread diameter.
New bushing: .985-OD .964-root thread diameter.
I haven't called chevs of the 40's yet.
Does anyone have a 49-54 bushing that they can measure the OD and root thread diameter on.
I have this idea for two reasons:
This is the same issue I had with the ones from ebay.
(So maybe an entire batch got screwed up at the factory)
If I believe the pictures in the chevs of the 40's catalog, the bushings (and seals) look like they are from a 49-54 pin.
39-48 pin: (my original looks identical)
http://www.chevsofthe40s.com/detail/8131/Chevrolet_LINK_PINS_UPPER_OUTER_W_SEALS.html49-54 pin: (my new pins have these bushing and seals)
http://www.chevsofthe40s.com/detail...ER_OUTER_W_SEALS_PASS_5362_CORVETTE.htmlJoe
