Vintage Chevrolet Club - Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
Owner: Rustoholic
New Lower Pin play #232465
01/28/12 08:19 PM
01/28/12 08:19 PM
St. Louis, MO
J
JoeS Offline OP
JoeS  Offline OP
J
St. Louis, MO
Should my brand new lower (steering knuckle) pins have any play in them. Mine sure do. They are not as bad as the orginals, but I was expecting zero play. Is that just the way it is?
Thanks.
Joe
Re: New Lower Pin play [Re: JoeS] #232499
01/29/12 12:40 AM
01/29/12 12:40 AM
Goulburn Australia
tonyw Offline
tonyw  Offline
Goulburn Australia
Joe
You say new knuckle pins, were the bushes replaced as well (that is what wears the most)? I would think no play (at least that is the way I set them) but should swivel freely.
Re: New Lower Pin play [Re: tonyw] #232535
01/29/12 03:21 AM
01/29/12 03:21 AM
St. Louis, MO
J
JoeS Offline OP
JoeS  Offline OP
J
St. Louis, MO
Outer lower link pins.
One of these:
http://www.chevsofthe40s.com/detail/8134...2_CORVETTE.html
I've installed it into the A-Arm/steering upright and there just seems to be an excessive amount of play, however, this is my first King-Pin car, so Im not sure what to expect.
There is no adjustment to this part.
Re: New Lower Pin play [Re: JoeS] #232556
01/29/12 11:42 AM
01/29/12 11:42 AM
Central Kentucky
kwchevy1940 Offline
kwchevy1940  Offline
Central Kentucky
Which way is the excessive play? Side to side? Or up and down? Could be you may have worn out bushings? idea
Ken's 1940 Special Deluxe Sedan
1970 Cadillac Hearse
Re: New Lower Pin play [Re: kwchevy1940] #232582
01/29/12 05:35 PM
01/29/12 05:35 PM
St. Louis, MO
J
JoeS Offline OP
JoeS  Offline OP
J
St. Louis, MO
The a-arm/steering is off of the car in the Vise.
These are BRAND new. That is my question. Should new ones have play?
Re: New Lower Pin play [Re: JoeS] #232585
01/29/12 05:54 PM
01/29/12 05:54 PM
The Great State of TEXAS
Chipper Offline
Chipper  Offline
There should not be any noticeable play between bushing and shaft. There are some "floating" bushings that have some play between housings and shafts. I don't know if this year and application is one of them.
Re: New Lower Pin play [Re: Chipper] #232590
01/29/12 06:19 PM
01/29/12 06:19 PM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
The thread between the bushing and pin is not a real tight fit....there will be a very slight amount of play. I will check out a genuine set later and give a reply.
Chevgene
Re: New Lower Pin play [Re: Chev Nut] #232601
01/29/12 08:55 PM
01/29/12 08:55 PM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
A new genuine has several thousands of play. Probably designed that way so greae would flow through .
Years ago we sold 10 uppers to every lower. If they get lubed every 1000 miles they will last forever. I use a grease with moly in it for mine.
Chevgene
Re: New Lower Pin play [Re: Chev Nut] #232635
01/30/12 02:55 AM
01/30/12 02:55 AM
Chipper Offline
Chipper  Offline
I don't feel that a few thousandths gap between pin and bushing would be noticeable unless paying strict attention. For greased joints 2+ thousandths gap is required for proper lubrication. Oil can be ~ 0.001 and still lube properly.
Re: New Lower Pin play [Re: Chipper] #232667
01/30/12 12:26 PM
01/30/12 12:26 PM
St. Louis, MO
J
JoeS Offline OP
JoeS  Offline OP
J
St. Louis, MO
Thank you for the replys, and I was afraid of that.
These are new, and there is much more than a few thousands play.
I purchased them from a vendor on eBay and am very dissappointed with everything that I've tried to use so far.
The bottom bushing requires a 26mm wrench. The bushing for the top pin (screws into the shock A arm) wont even start. The threads are obviously wrong.
This is VERY frustrating.
Re: New Lower Pin play [Re: Chev Nut] #232675
01/30/12 03:32 PM
01/30/12 03:32 PM
St. Louis, MO
J
JoeS Offline OP
JoeS  Offline OP
J
St. Louis, MO
So when I go to the autoparts store, and grease that has "moly" in it? Do you have a specific recommendation?
Thanks.
Joe
Re: New Lower Pin play [Re: JoeS] #232676
01/30/12 03:39 PM
01/30/12 03:39 PM
West Allis,Wi.
Chev Nut Offline
Chev Nut  Offline
West Allis,Wi.
The tube will say contains moly and it is the grease required by Ford so its easy to find. Get a major brand.
Chevgene
Upper link pin fit (was New Lower Link Pin play) [Re: JoeS] #233662
02/08/12 12:45 PM
02/08/12 12:45 PM
St. Louis, MO
J
JoeS Offline OP
JoeS  Offline OP
J
St. Louis, MO
Well I returned the kit I purchased from eBay and purchased new uppers and lowers from chevsofthe40s.
Guess what. Same problem with the uppers. The bushing wont even start to thread into the upper A arm.
(The old bushing hand screws in with no problem.)
I had a machinest look at the old and new bushings.
Old bushing: .979-OD .957-root thread diameter.
New bushing: .985-OD .964-root thread diameter.
I haven't called chevs of the 40's yet.
Does anyone have a 49-54 bushing that they can measure the OD and root thread diameter on.
I have this idea for two reasons:
This is the same issue I had with the ones from ebay.
(So maybe an entire batch got screwed up at the factory)
If I believe the pictures in the chevs of the 40's catalog, the bushings (and seals) look like they are from a 49-54 pin.
39-48 pin: (my original looks identical)
http://www.chevsofthe40s.com/detail/8131/Chevrolet_LINK_PINS_UPPER_OUTER_W_SEALS.html
49-54 pin: (my new pins have these bushing and seals)
http://www.chevsofthe40s.com/detail/8132...2_CORVETTE.html
Joe
Moderated by  37Blue
Your Status
Please register or login to post or reply. Forget Your Password?
Become a Member!
Helpful Links
Reset Your Password
Kill Your Cookies
Who's Online Now
0 registered members (), 1 guest and 4 spiders.
Key: Admin, Global Mod, Mod
Today's Birthdays
Truck1927
Member Photos
1942 Chevrolet oldies
1918 Model D-4
My Chevys
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
Newest Members
FB_Tweed, Dones475, aland, Stickdude, Achipmunk
15124 Registered Users
Forum Statistics
Forums69
Topics49,997
Posts362,511
Members15,124
Most Online304
Jun 18th, 2016
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
