#231333 01/18/12 10:25 PM
I need to replace the wire between the Ignition switch and the coil. This is the wire that is in the steel cover. I removed the tumbler which was no help.
Tim
#5049
timbeilby #231345 01/18/12 10:54 PM
To replace the electrolock wire you will have to remove the back of the lock cylinder housing with the armored cable.
timbeilby #231459 01/19/12 06:28 PM
Tim
#5049
Tim, you must be the fellow I just spoke with on the phone. The book from the Filling Station will give you the step by step how to. It's money well spent. <CLICK>
