Posts: 140 |
I need to replace the wire between the Ignition switch and the coil. This is the wire that is in the steel cover. I removed the tumbler which was no help.
Tim #5049
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Tim #5049 Tim, you must be the fellow I just spoke with on the phone. The book from the Filling Station will give you the step by step how to. It's money well spent. <CLICK>
