#97189 03/12/07 12:30 AM
oniz Offline OP
Were the roof moldings on a '30 Coupe like the belt molding? Like a half moon shape if you were looking at a end view. All of the roof material and moldings were missing when I got my car so any help would be great.Also, who has the best roof kits? Thanks in advance! Stan
oniz #97201 03/12/07 11:50 AM
If you are talking about the one piece moulding that goes down both sides of the roof behind the doors and then around the lower back of the roof line then yes, the roof moulding was "half-moon" shaped when you look at it from the end. And, the moulding is held in place with nails.
"Roof kits"? Can you be more specific?
:) wink :grin:
oniz #97214 03/12/07 01:23 PM
I don't know of anyone that has a duplicate of the top material. Hampton Coach supplies their version of the material and padding. However, I purchase mine from Model A suppliers like Snyders in Ohio. Much cheaper and likely the same stuff.
Chipper #97232 03/12/07 04:54 PM
Snyder are nice people, and have some very useful and identical parts to our 490ties. Still, when I made a complaint after a break down of a brand new pinion I bought there, I got into some trouble. They told they sold their parts "only" for use with Ford cars, so "Sorry, no guarantee in combination with Chevrolets. They had no trouble with the pinions and T-Ford planet gears. After some thought and checking the stock, they accepted to sell me a new pinion, and not the full set. And both were happy. dance
Solan G, # 32797
oniz Offline OP
Hey Dawg,I'm talking about the molding that goes around the top material. I think Chipper has me figured out. I'm not sure what I need because I've never seen another '30 Coupe. I know you're thinking I need to get out more often. Chipper, Thanks for the information! Stan
oniz #97272 03/12/07 11:43 PM
Ya just gotta be more specific! The roof crown moulding (that's what ya call it) is available from "Bob's Automobilia" in California. It is a by-fold moulding. I purchased some for my '30 coupe and it is dead on!
:) yipp yay
JYD, Is that "roof crown moulding" you say worked dead on on your '30 coupe. Also correct for '29 coaches? If so do you have a website address or phone number for "Bob's Automobilia"?
1929 Chevrolet: The Most Outstanding Chevrolet In Chevrolet History!
Capt. Harley
Isn't the Internet great? Just went to "Google" and typed in "Bob's Automobilia" and up came his web site. Go here:
http://bobsautomobilia.com/
Bob sells Buick reproduction parts, however, his roof crown moulding for the 1930 Buick is the same moulding for the 1930 Chevrolet also. The moulding was identical to mine (should be the same for 1929), however the mouldings come in long strips and the problem is you have to make a jig to bend the mouldings to fit the rear corners of the roof. And, since the mouldings are by-fold, they have to be bent in the open position.
:( :cry: wink
Dawg, Why would I want to go to "Google" when I've got you?!?!
In all seriousness Skip, thanks for the info. It is most appreciated. "Woof", "woof"........
Capt. Harley
And a big BOW WOW right back at ya!
:grin: bigl bigl
oniz #97398 03/14/07 01:39 PM
does anyone have any tricks for bending or forming the roof molding? I will have to replace mine on a five window coupe soon. Thanks
Sal Orlando
Chat Group Region Member
Since I am away from my references this is a risky answer. I seem to remember that the '29 top mouldiing is not the same as the '30 - '31. I will be home in a few days to double check.
Chipper #97437 03/14/07 11:37 PM
The Chevrolet roof crown moulding for 1930 is not the same as 1929. However, the Buick mouldings that Bob's Automobilia sells is for 1929-31, which will be the same moulding as used on a 1930 Chevrolet if ordered for a 1929 Chevrolet.
:) wink :grin:
Will they work on a 32 four door sedan as well???
Steve
Chevman #97490 03/15/07 07:50 PM
No, the mouldings are not the same.
:( :cry:
Is anyone reproducing ones for the 32??
Steve
Chevman #97511 03/15/07 10:56 PM
Not that I am aware of.
oniz Offline OP
WOW, I didn't think my little question would turn into a two page tread. I'm glad everybody jumped in on the subject! Dawg,can you describe your jig or fixture that you used to form the rear corners? If a picture would be easier, you can e-mail me. Any help would be great!! Thanks-a-million,Stan
oniz #97762 03/20/07 01:10 AM
A metal jig cut to the configuration of the proper radius was used, along with heat. Don't try this yourself.....get a professional to do it or you will ruin the mouldings.
:o :( :(
oniz #97832 03/20/07 11:22 PM
A piece of plywood and a couple of boards make a good jig to bend the '30-'31 style roof moldings. Cut the radius matching the top opening and extend it a little past the 90 degrees needed as the molding will come back after being bent. Clamp the plywood to a table or larger piece of plywood. Mark the location on the start of the bend and then using boards and clamps secure the molding in place so it can not move up or out away from the jig. Place the side closest to the piece to be folded down against the jig. Slowly bend the molding around the jig. You may need to use a few clamps to hold it in place as you bend it. You will find that the verticle center bead will move down as you make the bend. It is ok as long as it does not close completely. Once the bend is completed and the molding nailed in place then tap the center bead down starting at the corner. Use a block of wood and go slow and work it down a bit at a time. It will result in a good job with not lumps or bumps if you are careful.
Chipper #97836 03/20/07 11:35 PM
Stan: Keep in mind that the roof crown moulding for your 1930 coupe is a bi-fold type (as mentioned in Chipper Whipper's posting above) which makes it more difficult to bend around the radius of the top so be careful when bending.
Chipper #98156 03/26/07 12:12 AM
oniz Offline OP
Chipper,thanks for the information!! I'll have to get busy and see about getting the moldings and building a jig. Thanks to all for the help on my project!!!!! I don't think I could ever get it going without all the gangs help. Stan
oniz #98169 03/26/07 10:42 AM
dog and chipper you did not explain how to bend the front piece ?the back is easy as you can do some bending or tweeking on the car as you nail it .
