#58525 09/17/06 12:04 AM
A friend just acquired an early FB engine, complete. He really wants to get rid of it. Is anyone interested? I think it maybe from an Olds truck. It has the transmission too, and is huge, with square pedals. It appears to have a four speed transmission with a power take off.
Larry
#58526 09/17/06 01:46 AM
If you post the numbers and letters that are found cast on the block as they appear then we can likely tell what year and application. Since the cars and trucks used the same engine and transmission if might fit either.
Does it run? If not what parts are missing? Does is turn over or the crankshaft rotate? Transmission shift between gears? It should have a standard "H" pattern and be a three speed if original FB.
How much does he want for it?
#58527 09/19/06 12:56 AM
FB motors, did they have the 3-port head or were they just 1-port?
Cheers
Jimmy
chevy
#58528 09/19/06 11:18 AM
Yes! The '19 to '21 models had a single port head. The '22 had the three port.
#58529 09/19/06 12:22 PM
What is a FB motor?...Oscar :confused:
OSCAR ALBRETSEN
#58530 09/19/06 02:32 PM
The FB motor has a block, a lower crankcase casting and a oil pan. It was used in the bigger cars and 1 ton trucks. There is another 4 cylinder engine the FA that has a block and oil pan only it uses a 1 port head. Real good pictures of both in the "Parts List for 1 ton truck model T" issued Sept 1, 1923.
#58531 09/20/06 05:43 PM
Thanks 35 pickup man, I will run down to the drug store and pick up a Sept 1, 1923 issue this afternoon. bigl bigl bigl wazzup
OSCAR ALBRETSEN
#58532 09/20/06 07:28 PM
Would you like a copy???
#58533 09/20/06 08:13 PM
G'day 35 pickup man, I would like a copy if you don't mind!
Does anyone know where I can get the rocker arms for a FB 3-port?
Cheers
Jimmy
chevy
#58534 09/20/06 09:50 PM
rod Offline
That must be an old old drugstore. :eek:
rod
#58535 09/22/06 02:54 PM
Jimmy B Made copies of engine FA & FB parts for you; will put in mail tomorrow.
#58536 09/24/06 05:56 PM
Thank you! I will let you know when it arrives.
Cheers
Jimmy
chevy
#58537 09/28/06 03:27 AM
I'm going to move this thread to the 4-cyl forum. (...though it most properly should be in the For Sale forum.) I think it will be more appropriate there.
1924 Superior "F" Touring Car
#58538 09/28/06 05:40 PM
If the clutch and brake pedals are very large and square,and the gear lever stands vertical,it's probably a 4 cyl engine out of an Oldsmobile Economy Truck.A real dead give away will be,that it would have the Oldsmobile "script" cast on the inlet manifold riser/hotbox.
chevy
CJP'S 29
#58539 09/28/06 11:48 PM
Downunder we have found a number of FA-FB Chevs, a couple of complete cars and quite a few wrecks, so they must have been exported to Aus. Although you'd wonder why.
I have two of those 3 port heads that I picked up at local swap meets, and no! they arn't for sale
Chris
#58540 09/29/06 11:31 PM
I received them today, thank you!
It is good to have this type of reference in the library.
That is good to know I thought they were more scarce here than the US :) I have one of these heads and I do not want to sell it ever!
Cheers
Jimmy
chevy
