Posts: 3 |
A friend just acquired an early FB engine, complete. He really wants to get rid of it. Is anyone interested? I think it maybe from an Olds truck. It has the transmission too, and is huge, with square pedals. It appears to have a four speed transmission with a power take off.
Larry
If you post the numbers and letters that are found cast on the block as they appear then we can likely tell what year and application. Since the cars and trucks used the same engine and transmission if might fit either.
Does it run? If not what parts are missing? Does is turn over or the crankshaft rotate? Transmission shift between gears? It should have a standard "H" pattern and be a three speed if original FB.
How much does he want for it?
Posts: 81 |
FB motors, did they have the 3-port head or were they just 1-port? Cheers Jimmy
Yes! The '19 to '21 models had a single port head. The '22 had the three port.
Posts: 934 |
What is a FB motor?...Oscar :confused:
OSCAR ALBRETSEN
Posts: 988 |
The FB motor has a block, a lower crankcase casting and a oil pan. It was used in the bigger cars and 1 ton trucks. There is another 4 cylinder engine the FA that has a block and oil pan only it uses a 1 port head. Real good pictures of both in the "Parts List for 1 ton truck model T" issued Sept 1, 1923.
Posts: 934 |
OSCAR ALBRETSEN
Posts: 988 |
Posts: 81 |
G'day 35 pickup man, I would like a copy if you don't mind! Does anyone know where I can get the rocker arms for a FB 3-port? Cheers Jimmy
Posts: 83 |
That must be an old old drugstore. :eek:
rod
Posts: 988 |
Jimmy B Made copies of engine FA & FB parts for you; will put in mail tomorrow.
Posts: 81 |
Thank you! I will let you know when it arrives. Cheers Jimmy
Posts: 194 |
I'm going to move this thread to the 4-cyl forum. (...though it most properly should be in the For Sale forum.) I think it will be more appropriate there.
1924 Superior "F" Touring Car
Posts: 1,213 Likes: 1
Posts: 1,213 Likes: 1 |
If the clutch and brake pedals are very large and square,and the gear lever stands vertical,it's probably a 4 cyl engine out of an Oldsmobile Economy Truck.A real dead give away will be,that it would have the Oldsmobile "script" cast on the inlet manifold riser/hotbox.
CJP'S 29
Posts: 809 |
Downunder we have found a number of FA-FB Chevs, a couple of complete cars and quite a few wrecks, so they must have been exported to Aus. Although you'd wonder why. I have two of those 3 port heads that I picked up at local swap meets, and no! they arn't for sale Chris
Posts: 81 |
Originally posted by 35 pickup man: Jimmy B Made copies of engine FA & FB parts for you; will put in mail tomorrow. I received them today, thank you! It is good to have this type of reference in the library. Originally posted by chevguroo: Downunder we have found a number of FA-FB Chevs, a couple of complete cars and quite a few wrecks, so they must have been exported to Aus. Although you'd wonder why. I have two of those 3 port heads that I picked up at local swap meets, and no! they arn't for sale That is good to know I thought they were more scarce here than the US :) I have one of these heads and I do not want to sell it ever! Cheers Jimmy
