Hello all, I have come to bow down and ask my first question because I am stumped.
I am helping a friend with his 1949 Chevrolet 3100, It came in as a no charge.
After a few tests I came to the conclusion it needed a voltage regulator.
I replaced it with a Standard brand regulator, I now have voltage to the regulator but cannot get the field coil to energize on its own?
If I manually energize it, it will hold for an extended period of time, but once it disconnects it goes back to just arching?
I have cleaned the grounds from battery to frame to engine. I could not locate the cab ground so I ran a ground to the voltage regulator body, still nothing.
Once energized it performs as should?
I know this is probably simple and I am just not thinking , but I've pulled my hair out and now I am here?
