Hello Michael Paul,
These are wise and good suggestions to follow. To add a suggestion to the following of the wiring diagram and reviewing photos, a paint marker pen comes in handy to mark both the terminal stud and the original wiring terminal end before undoing the connection. This will keep the confusion down to be able to match the new wire to the old wire and know which terminal stud to connect to. If you don't want to use marking paint, a bag of multi colored zip ties could do the same thing. One wire (swap) at a time is a proven way to keep confusion in check. Sometimes, in order to install a new wire, the old wire needs to be pulled out to make room for the new wire (tight routing areas, grommets and such). Having the new wire marked matching the old wire will make sure where the wire goes. Do that for both ends of wires and for verification of electrical connections, check them using a continuity meter. Checking a wrong connection with 6 or 12 volt might ruin components and wiring. Edit: The terminal studs could use some penetrating oil and use two wrenches when removing and installing connections to avoid damaging components.
