You might have more success looking for a complete rear axle.
Maybe I missed something. Do you already have a new ring gear? If the pinion is worn I would expect simialr wear on the ring gear. Running a new pinion on the old ring gear will probably only work for a while.
The part number listed is correct for a 4.11 gear SET-ring and pinion. The poster is in France so probably some language conversion issue. That gear set also list for 37 and 38 1/2-3/4-and 1 ton trucks. Perhaps someone that has changed their truck rear axle may have a good used one.
I viewed that same item and have emailed the seller questioning if it is for a master or std and he replied he has both,. I am waiting to see if there are ANY numbers on the parts to identify them. The red flags are already up as he listed only as for a 36 Chevrolet - said he has both std and master . At least it's an Ebay listing so there is a process in place if not correct to get a refund even though the ad says no returns.
He replied that they had a family parts and scrap yard business for 90 years and the info he is supplying is what the box is marked. I still asked for numbers on the parts even though they are probably not OEM and who knows if the parts are in the correct box. Seeing that they need to go to France all the info we can get is best.
I looked at ebay but I've never found what I expected. I think this part is really difficult to find ... Thanks for telling me if you have any contact.
I agree the one pictured in the Ebay ad is for a std . I used contact the seller feature as the ad did not specify and he replied he had both and would get some numbers today. If that does not happen I have to assume he did not find a correct master gear set. Following is a copy of the Emails. Newest reply at top.
New message from: dun_1946 (510PURPLE_STAR Star) I can check tomorrow Reply
Your previous message I prefer the numbers on the parts if any .
dun_1946: We had a family owned 4 generation parts store and salvage yard for 90 years. The boxes are marked with application. I can take a picture of that for you.
Your previous message Looking for a set for a Master for another person. Are there any numbers at all on either part? How can you be sure of application? Item will need to be sent overseas so want to sure it is correct and will then advise buyer to purchase direct.
dun_1946: I have both master and standard. No not have the GM part numbers
Your previous message Is it for a Chevrolet Master or Standard?? Any numbers on either part?? If so please list. TY
Hi i have a ring and pinion set from a 37-40 1/2 ton . It is a replacement set made by the AUTOMOTIVE GEARWORKS CO. pinion#8470 ring#7470 9 3/8 diameter 12 hole. If some one can verify this info please chime in.
Hi inner dia 5.440 inch /13.8 cm outer 9.375 inch/23.81 cm pinion 9.125 inch/23.18 cm Note: I am not set up to measure this large so these measures are not exact margin of error is about plus or minus .025 inch
