#488395 01/05/24 12:30 PM
Bertus Offline OP
Side panels under dash (at floor/toeboard) should have upholstery material or are they just painted black?
1932 Chev 5 Window Coupe
Bertus #488437 01/06/24 07:03 PM
They were (and still are) vinyl covered paperboard in my 38.
Bertus #488457 01/07/24 09:43 AM
The reproduction ones that came from HC in my 32 appear to be just paperboard and NO vinyl.
Bertus #488480 01/07/24 04:54 PM
In my ‘37 Master coupe the panels were more like a heavy cardboard with some type of what I would call paint on them. They definitely were not covered in vinyl.
Bertus #488487 01/08/24 12:33 AM
Most upholstery suppliers sell a heavy black cardboard that is used for that application. It may even have a wax in it to make it somewhat water resistant. I have the original set for my '29 coupe. It had a textured surface on it. A Durant that was restored for our friend had textured cardboard that looked like alligator hide.
Bertus #488500 01/08/24 10:43 AM
Bertus Offline OP
Car is a '32 5 window sport coupe. I am using 1/8" hard board (aka masonite).
Thanks for the replies. No one indicated upholstery material here so I guess I'll just paint them black.
Bertus #488517 01/08/24 02:02 PM
My personal opinion is that the masonite will not accept the paint readily. The paperboard will absorb the paint so it does not chip or flake off.
Bertus #488521 01/08/24 02:21 PM
Bertus Offline OP
Will sanding before painting solve the problem?
Bertus #488523 01/08/24 02:47 PM
I used Jesso (I think that's the name) on a cardboard sun visor. It accepted the paint.
DAinSanJose #488537 01/08/24 05:34 PM
Bertus Offline OP
The masonite is brown and unfinished. It sands easily. Basically compressed paper or sawdust I think. I used 3M Super 77 spray adhesive for a couple of the other panels to attach upholstery material. Seems to work well.
Bertus #488564 01/09/24 08:35 AM
I have no experience with the thin masonite you refer to but if it's like the 1/4" stuff I do have experience with, sanding it should give it enough tooth to adhere. It's the gloss that's the enemy.
Bertus #488586 01/09/24 06:17 PM
I used some that was closer to 3/16 to make the rear window tray (package tray) in my 67 Cougar. It was smooth on one side and textured on the other. I wanted the texture to mimic what the package trays were like originally. Took paint quite well. Now if I had used the smooth side...IDK.
I was planning on using what is left of the 4x8 sheet I bought to make the kick panels for my 28 truck as well as the panels that go behind the doors aside of the seat.
Think I got it at Home Depot.
David
