#487417 11/30/23 11:02 PM
1010 Offline OP
I have a 1960 inline 6 cylinder 261 cu. in. engine. Does anyone know the correct size water pump pulley for this engine?
Thank you.
1010 #487428 12/01/23 12:12 PM
There were several 6 cylinder water pump pullyies used an the diameter depended on the application. A 261 truck would have had a rather small diameter pulley as it could have been used on a truck carrying heavy loads. If this 261 engine has been transplanted to a car or small truck you could use a pulley from a 1959-1962 6 cylinder car.
I should add I would use the smaller passenger car fan blade also.
1010 #487439 12/01/23 05:15 PM
1010 Offline OP
Thank you for your reply. Do you know the diameter and height of the 1959 - 1962 6 cyl car pulley. My 261 cu. in. engine was installed in a 1950 1/2 ton pick up truck. My problem is the water pump stands out to close to the radiator. I could not fine a short shaft water pump in my area. I purchased a new 1957 chevy water pump that should work after I press down the hub and cut off the excess shaft. The pulley that came off the truck is 4-1/4" OD, Height is 1-3/8", pulley holds a 5/8" belt. (the crank pulley is 6" OD with 5/8 belt). I have some wiggle room on the height of a new pulley and could use up to a 2-1/2" height. I've called Summit and others no luck. Looked on the internet but rarely find the height. Thank you.
1010 #487441 12/01/23 05:28 PM
You have the option of using an electric water pump. You can put it about any place. Of course you'd have to use an electric fan as well I believe.
