Is there any type of weather seal on the doors that goes in between the glass and the outside of the door channel/window channel that prevents water from running down the windows and into the door? I have the piece that staples on to the interior trim piece that has felt on it but I am unsure if there is something similar that was meant to go on the outer side of the glass. I hope I posted a picture correctly.
Thank you
Judd
Judd J.
VCCA# 49599
1938 Master Deluxe Town Sedan
https://vcca.org/photos/alumni/gallery/46778077/20201124_221059_21646.jpg
There is nothing there. Thats is why it is important to keep the drain holes on the bottom of the door open.
2 members like this: Pappys38, Clement
iagree Nearly every case of rust out along door bottoms and fender bottoms is caused by plugged drain holes. If you've never run a vacuum along the inside bottom of your doors it's probably a good time to do so.
