Originally Posted by Chev Nut
There is nothing there. Thats is why it is important to keep the drain holes on the bottom of the door open.
iagree Nearly every case of rust out along door bottoms and fender bottoms is caused by plugged drain holes. If you've never run a vacuum along the inside bottom of your doors it's probably a good time to do so.
