#487121 11/19/23 12:42 PM
31sedan Offline OP
I have a 31 sedan that needs to be rewired. Does anyone have a schematic that shows wire color and gauge for a 6 volt system?
I doubt if the wires are color coded.
Jon T.
This is the best wiring diagram i expect that you will find. I have never seen one that shows wire gauge. In some of the diagrams for "newer" vehicles. they might show the color-coding.
My advice is to save yourself a lot of time and grief. Order a harness from YNZ or Rhode Island Wiring.
Chevy Wiring Diagrams
1 member likes this: Clement
Lou Offline
. The 1931 wiring diagram doesn't show wire color after 1928. <https://chevy.oldcarmanualproject.com/electrical/wiring/pdf/31lighting.pdf> . Lou .
Attached PDF document
31sedan Offline OP
Thank you for the input. The wiring is not that complicated. I just figured if there was a diagram to follow, it would be more Era correct.
Agree with Rusty37Master. I used a YnZ in my 48. Was worried about putting it in. The installation turned out to be very easy. I removed the seats, threw in some old blankets an the floor. That made it easy to get under the dash.
