#486747 11/04/23 10:35 AM
Bertus Offline OP
I am electrically challenged. Is there a simple way to test an electrolock?
1932 Chev 5 Window Coupe
Bertus #486748 11/04/23 10:53 AM
What are you wanting to test? The continuity?
Bertus #486749 11/04/23 10:59 AM
Bertus Offline OP
Yes
Bertus #486750 11/04/23 11:36 AM
Use a multi-meter and connect it as shown below with the key in the on position. If the continuity is good it'll read all 0s. The pictures below are me testing mine following a rebuild.
1 member likes this: Clement
Bertus #486751 11/04/23 11:40 AM
Bertus Offline OP
Yes
Bertus #486789 11/05/23 05:50 PM
Check the centre wire for continuity,on off switch, and also check the centre wire for contact with the outer cable.
JACK
Bertus #487445 12/01/23 07:01 PM
Bertus Offline OP
All good. Electrolock installed and working. Many thanks!
Bertus #487450 12/01/23 09:20 PM
Great! You are now on the way to being a cracker jack mechanic.
Bertus #487455 12/02/23 09:15 AM
Bertus Offline OP
Not sure about crackerjack but we do learn something new everyday, and this forum is certainly a great help.
