Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
I have 1895 Light Bulbs in my Dash Lights on my 55. They are not very bright at night. Is there a brighter bulb I can use?
Jon T.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Does the brightness change if you rotate the light switch knob? If not then perhaps the rheostat in the switch has failed.
It does change. And looking at it last night it may be a little brighter.
Jon T.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
By all means make sure your rheostat is working normally. If they're still not bright enough try 6253 bulbs. The 1895 has 25 lumens while the 6253 has 53.
Thanks for the help.
Jon T.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I have discovered numerous "tricks" to making the dash lights brighter in older classic vehicles.
- Just replacing the bulbs will help. The light output of filament bulbs diminishes over time. Even replacing a 10 year old bulb makes a difference. - Cleaning the inside of the glass/plastic instrument covers makes a big difference. - Painting the inside of the instrument housing gloss white is a real benefit. Due to heat from the bulbs, time, and dirt those surfaces really darken. - As Tiny noted, make sure the rheostat and wiring, especially the connectors and grounds are clean with no oxidation. - I would consider going to a brighter bulb if it will fit and you know that the extra heat will not cause damage.
I know that there are lots of people who are sold on LED's. I'm not in that camp. In many cases they are actually too bright. Many of them are not dimmable. A third problem is that the geometry of the bulb might not project the light where it is needed.
1 member likes this:
Clement |
