The handle to turn on the lights was making a scraping noise of metal to metal.
Took switch apart and found that three original small springs broke. Also, the brass, grooved “ring” was damaged due to a broken spring and by turning the switch. I bought a small width spring and tried to cut it to length.
Put it all together, switch moved easier without the noise. Installed it, hooked up wiring and the switch does not work.
I do have power coming into the switch but nothing seems to work with a test light and the electrical connectors in the switch.
I removed all wiring and turned in the wire holding screws to get a better connection. Nothing happened when I turned on the ignition switch and tested with a test light. Is there a correct spring length? This should not be as complicated as I am making it out to be, but sometimes we cannot see the forest through the trees. Any thoughts? Thanks
Well, every now and then creamed crow on toast is edible. I overthought the electrical problem and finally took a chain saw to cut down the forest to see the trees, or is it cut down the trees to see the forest? Thanks for many of you that read the question.
Support The VCCA!
Member Photos
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
Who's Online Now
8 members (ruscar, Rons38MD, Stovblt, kaygee, Dave39MD, JohnS, David_S, 1 invisible), 90 guests, and 14 robots.
Key: Admin, Global Mod, Mod
Newest Members
Chevrolet490nor, RickyMullen, CaptainD, orangeleeroy, PaulKennelly
18,043 Registered Users
Today's Birthdays
There are no members with birthdays on this day.
Forum Statistics
Topics58,551
Posts425,363
Members18,044
Most Online1,133
Jan 22nd, 2020
