#483240 07/07/23 01:23 PM
Howdy
We picked up a 41-46 Chevy 3/4 Ton AK series from the guy that had it in the bushes. The Last Project
I say the dates 41-46 since the cab has the post-41 door latch and back window fitting but the engine is coded 41 and I have not been able to access the trans #, cab tag and reg is 46.
That said I am hoping to restore if the 216 is able to be freed and I'll need a carb when we get there
Torq Tube and diff in the bed, rust, body work etc and I am getting old so its the last project
Thanks ...von
Have a "Blog" for this going https://1941chevrolet.blogspot.com/
Become a Member!
Welcome to the forum, and good luck with your project, vonkluver. We are looking forward to seeing pictures. Where is Walnut Creek?
Bill Masters
Welcome!
A quick watch of your video suggests a 1946 with the rubber rear window mount and door lock location as you point out.
And the chrome grill.
It's not a '41.
Early production '42 may have had chrome (someone else may know this for sure).
No 3/4 ton or 1 ton trucks were produced for civilian sale through the war and right up until the second series 1946's.
If it's a 1946, the serial number should have a "DR" in it.
What is the engine number?
Again, from a fellow '46 3/4 ton owner... welcome!
Ole S Olson
An AK is a 1941 1/2 ton
The 3/4 ton is an AL
If I remember corectly the 1/2 ton has 6 wheel studs and the 3/4 ton 8.
