#481469 05/08/23 11:48 AM
I need a working radio for a 1950 Bel Air, push button if possible.
Bill Pierson
Support The VCCA!
luggnutt #481470 05/08/23 12:06 PM
I have one rebuilt by Ray Holland for a '51 if that would work.
luggnutt #481476 05/08/23 03:40 PM
Unfortunately i don't think that will work. If I remember correctly a 1950 radio was a vertical faceplate design. In 1951 Chevy switched to a horizontal faceplate.
luggnutt #481479 05/08/23 04:52 PM
I wasn't sure but thought there was a difference. Maybe someone else would be interested?
luggnutt #481486 05/08/23 10:18 PM
Thanks , but the one I need is the vertical mount.
luggnutt #481490 05/09/23 01:57 AM
i have a couple of 1950 working radios one i had redone by some guy in washington , if you are still looking write me back Andy in ohio
luggnutt #481701 05/14/23 08:35 PM
Bill, the '50 radio is a two-piece affair with one section containing the tuning controls and the other section the speaker and tubes. Some people see the section with the push button tuners at a swap meet and think they've struck gold, but they have only found half of the treasure. The '51-'52 radios are one-piece. The '49 will fit a '50 but the colors are different.
luggnutt #481707 05/14/23 11:19 PM
I have an original 49-50 chevy pushbutton radio and speaker pack for 200.00 will need restored to play music. mike mccagh
luggnutt #481711 05/15/23 03:26 AM
My inventory contains both 49 and 50. Brown for 49, Grey 50. Mine can be upgraded with am fm bluetooth usb regardless if you've changed over to 12 volt neg ground. Can do 6 volt also. These do not need the amp power supply section. Fit and appearance doesn't change. Still the 49 or 50 radio. New electronics guaranteed for a year. Mine are push buttons. Not fixing any just upgrading.
Contact me for more information: bill@billtheradioguy.com
