Posts: 144 Likes: 1
Posts: 144 Likes: 1 |
I need a working radio for a 1950 Bel Air, push button if possible.
Bill Pierson
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
I have one rebuilt by Ray Holland for a '51 if that would work.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
Unfortunately i don't think that will work. If I remember correctly a 1950 radio was a vertical faceplate design. In 1951 Chevy switched to a horizontal faceplate.
I wasn't sure but thought there was a difference. Maybe someone else would be interested?
Posts: 144 Likes: 1
Thanks , but the one I need is the vertical mount.
Posts: 1,072 |
i have a couple of 1950 working radios one i had redone by some guy in washington , if you are still looking write me back Andy in ohio
Posts: 337 Likes: 4
Posts: 337 Likes: 4 |
Bill, the '50 radio is a two-piece affair with one section containing the tuning controls and the other section the speaker and tubes. Some people see the section with the push button tuners at a swap meet and think they've struck gold, but they have only found half of the treasure. The '51-'52 radios are one-piece. The '49 will fit a '50 but the colors are different.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
I have an original 49-50 chevy pushbutton radio and speaker pack for 200.00 will need restored to play music. mike mccagh
Posts: 97 Likes: 1
Posts: 97 Likes: 1 |
My inventory contains both 49 and 50. Brown for 49, Grey 50. Mine can be upgraded with am fm bluetooth usb regardless if you've changed over to 12 volt neg ground. Can do 6 volt also. These do not need the amp power supply section. Fit and appearance doesn't change. Still the 49 or 50 radio. New electronics guaranteed for a year. Mine are push buttons. Not fixing any just upgrading. Contact me for more information: bill@billtheradioguy.com
