#480936 04/23/23 10:55 AM
Trip Offline OP
In the fall of 2021 I put my 46 chevy 1/2 ton into storage for the winter-drained the carburetor and added stabil to the 1/2 tank of gas. Due to work and travel Diane (yes she has a name and was featured in the magazine-A Tale of Two Dianes) has sat since then. Is it ok to start her or should I drain the gas first? Thanks for whatever knowledge you all can share.
Trip Hunter
Trip #480937 04/23/23 12:42 PM
With the stabil you "might" be OK but personally I'd replace the gas just to be safe.
1 member likes this: Trip
Trip #480943 04/23/23 01:33 PM
If the gas is from 2021 i would get rid of it, Stabil or not.
Trip #480953 04/23/23 09:55 PM
I think the info on the Sta-Bil bottle says it is good for 3 months.
Trip #480958 04/24/23 05:04 AM
I have used fuel 4 or 5 years old in 4 stroke engines and only once I had problems that I could attribute to stale fuel which was more like water in the fuel. 2 stroke outboard boat engines are a different story 3 months after mixing.
1 member likes this: Ed_Osier
tonyw #480968 04/24/23 10:57 AM
Trip Offline OP
Thanks so much Tony!
35Mike #480969 04/24/23 10:58 AM
Trip Offline OP
Thanks 35 Mike.
Trip #481100 04/28/23 07:23 PM
Consider draining that precious stuff only after your have tried to start it - trying everything - and the stinkin' thing won't crank. Those who say drain it must have deep pockets! Gasoline is $3.50 a gallon down here right now. Mercy! Agrin
Sorry about saying that sweet Diane (Da truck) stinks but she probably hasn't had a bath since you parked her. Where's you sense of adventure. Get you some starter fluid and have at it. Let us know how it turns out. dance
Charliecomputer
BTW: Have the other Diane present so she can give you a couple cartwheels and hugs for saving money..
Trip #481108 04/29/23 04:54 AM
The best way to drain the tank is to drive the car until it is near empty, when you do undo the drain plug catch the result and pour it into your snowplough, we dont need no snow plough down here.
Think yourselves lucky at $3.50 a gallon, petrol down here is $au2.00 a litre and only 4 litres to your gallon and 66 cents to your $. I mainly use what you call BBQ gas at $1.20 / /litre.
