#480577 04/11/23 03:04 PM
rjp Offline OP
Looking for what I need on a Carter W1 carb on a 32 Chevy: the hand throttle linkage on the carb. or even a good picture so I can find one Thanks
rjp #480633 04/13/23 03:57 PM
This is what I have on my 1932. Not sure, but beleive it`s correct for 1932.
rjp #480635 04/13/23 05:04 PM
I will take a photo of mine which is different. May be a couple of hours. A swivel arm is located on the bellcrank so that when the cable is pulled it pulls on the bellcrank lever that the foot throttle rod attaches to. At least that is how mine is hooked up .
m006840 #480644 04/13/23 08:20 PM
Photos have been added in previous post.
rjp #480687 04/14/23 09:15 PM
rjp Offline OP
Good pictures It looks like one factory and one home made but works. Thanks
rjp #480725 04/16/23 10:12 AM
rjp Offline OP
Would anyone have a good image on how the hand throttle wire is ran to the bell crank, Do you use the bracket on the carb to hold the cable ?
rjp #480726 04/16/23 10:37 AM
The cable is held by the bracket on the top of the intake manifold. Same as the choke which is held on the other side of the manifold.
rjp #480736 04/16/23 03:05 PM
rjp Offline OP
Ok, I got that double bracket but the throttle lines up the foot linkage and rubs. Dont look right
