Looking for what I need on a Carter W1 carb on a 32 Chevy: the hand throttle linkage on the carb. or even a good picture so I can find one Thanks
This is what I have on my 1932. Not sure, but beleive it`s correct for 1932.
I will take a photo of mine which is different. May be a couple of hours. A swivel arm is located on the bellcrank so that when the cable is pulled it pulls on the bellcrank lever that the foot throttle rod attaches to. At least that is how mine is hooked up .
Photos have been added in previous post.
Good pictures It looks like one factory and one home made but works. Thanks
Would anyone have a good image on how the hand throttle wire is ran to the bell crank, Do you use the bracket on the carb to hold the cable ?
The cable is held by the bracket on the top of the intake manifold. Same as the choke which is held on the other side of the manifold.
Ok, I got that double bracket but the throttle lines up the foot linkage and rubs. Dont look right
