The rest of the story:
Lost bolt. Went to Northern Tools and bought a couple magnets to help me search for the lost bolt down the fuel pump hole. That didn't work
Went and bought another bolt and washer. Later while putting the fuel pump off and on I ended up loosing another bolt and washer, Again probing with magnets produced a "no joy."
Was about ready to go buy another bolt but thought: I may be missing just where the bolt had gone if not in the oil pan. Crawled under the front of the car and felt all along all places they could have gone. Lo and behold! I found both of them about midway on the backside of the crossmember flange. They both were right there in the same place.
Reinstalled the new fuel pump from O'Riellys. No joy. Tried it again. Still no joy. (This was about umpteenth time I had installed this fuel pump with no joy each time. My new starter fluid can was getting pretty light. Now the way I figure this is that if you get the new pump on it has to pump when the cam lobe comes around. Right? Checked the arm on the pump against the old one. Same angle. So what in the world os going on here? Took a length of hose and sucked on the fuel ling where it meets the pump. Got joy! Plenty of gas right there. Put the pump back on again. More tries with the starter fluid. No joy.
What to do, what to do. Frustrated I choose to visit my pile of old correct fuel pumps (with bowl) and see if any had and suction when mashing the lever down. Several did emit the "sore throat Bull Frog hick-up". I selected the best looking one and put it on. Just two times with starting fluid and the engine caught and was running on its own. Imagine that!
Owing to the my lack of faith in the old pump's diaphram (sp) lasting very long, I'm gonna choose two more my old sucking pumps and the new one and put them in the trunk and make sure I put the necessary 1/2 inch and 9/16 line wrenches in there too.
I envy any of you who can just go to the store and buy a fuel pump for an old 216, 207 or 235 or whatever andput the sucker on and it then function as it should without the problems and headaches I encounter. Do too!
Thanks for bearing with me and sharing my pain.
Best,
Charlie
BTW: When on my knees and looking under the car for the second lost bolt, I got over balanced and couldn't arrest met fall toward the concrete floor. Bonked my noggin real hard. Big goose bump on my scull above my right eye. Two days later had the mother of all black eyes. The swelled goose egg can barely be felt there now but the black eye is still slowly, slowly going away. Yes, some two weeks later it is about half gone. Woe is me. I look like I've been caught by a jealous husband and then got the tar beat outta me. (Don't I wish) Do too!
