#480420 04/05/23 07:17 PM
Because the answer to this question covers several years, I'll ask art here in the forum,
Nothing gives me more trouble than installing a fuel pump on a 41. I have been trying to get one in most of yesterday and today. No way. When I do get in it decides not to pump. stressed
Question are there any suggestions before I put a 45 round through the block? Yes, I feel like it. I get it on sometimes and then the d-- thing won't pump. How can that be?
While down there trying to get the bolts in they just fall out and I have to scramble under the car to find them and get them out. I am now using a length of heater hose to lasso them. The last time before I quit for the day one of the bolts and washers disappeared. Maybe it want into the crankcase, I don't know and I not worried about it. What harm can it do owing that it will most likely just sit in the bottom of the pan. I go get another bolt and washer. Several of them. Sounds like a plan to me.
Anyone have any ideas for me on how to make this always dreadful job easier? If so please help. dance
Thanks a heap,
BTW: I ani't getting any younger and what used to be enjoyable and easy isn't so much fun anymore. You know.
Charlie,
Get the kid next door or down the block to put it on. Make sure he (or she) knows which end of the wrench to use first.
Charlie,
know where you are coming from and share he same feelings.. potty
One trick for me that reduced the agony was turning the engine over so the fuel pump cam lobe was not pushing on the lever. It still takes some finesse to get the bolts started but you are not fighting the spring pressure
I also glue the gasket to the pump so I am not fighting to keep it in position.
The third trick is to use a long bolt temporarily so you can get at least one started.
Thanks for the advice I've received so far.
Chipper, I'm talking about a stinking' fuel pump here not a cell phone. Although for the latter you would be "right on." Agrin
Rusty, what you advised will be helpful. Thanks. dance
Best
run an electric fuel pump
The rest of the story:
Lost bolt. Went to Northern Tools and bought a couple magnets to help me search for the lost bolt down the fuel pump hole. That didn't work
Went and bought another bolt and washer. Later while putting the fuel pump off and on I ended up loosing another bolt and washer, Again probing with magnets produced a "no joy."
Was about ready to go buy another bolt but thought: I may be missing just where the bolt had gone if not in the oil pan. Crawled under the front of the car and felt all along all places they could have gone. Lo and behold! I found both of them about midway on the backside of the crossmember flange. They both were right there in the same place.
Reinstalled the new fuel pump from O'Riellys. No joy. Tried it again. Still no joy. (This was about umpteenth time I had installed this fuel pump with no joy each time. My new starter fluid can was getting pretty light. Now the way I figure this is that if you get the new pump on it has to pump when the cam lobe comes around. Right? Checked the arm on the pump against the old one. Same angle. So what in the world os going on here? Took a length of hose and sucked on the fuel ling where it meets the pump. Got joy! Plenty of gas right there. Put the pump back on again. More tries with the starter fluid. No joy.
What to do, what to do. Frustrated I choose to visit my pile of old correct fuel pumps (with bowl) and see if any had and suction when mashing the lever down. Several did emit the "sore throat Bull Frog hick-up". I selected the best looking one and put it on. Just two times with starting fluid and the engine caught and was running on its own. Imagine that!
Owing to the my lack of faith in the old pump's diaphram (sp) lasting very long, I'm gonna choose two more my old sucking pumps and the new one and put them in the trunk and make sure I put the necessary 1/2 inch and 9/16 line wrenches in there too.
I envy any of you who can just go to the store and buy a fuel pump for an old 216, 207 or 235 or whatever andput the sucker on and it then function as it should without the problems and headaches I encounter. Do too!
Thanks for bearing with me and sharing my pain.
Best,
BTW: When on my knees and looking under the car for the second lost bolt, I got over balanced and couldn't arrest met fall toward the concrete floor. Bonked my noggin real hard. Big goose bump on my scull above my right eye. Two days later had the mother of all black eyes. The swelled goose egg can barely be felt there now but the black eye is still slowly, slowly going away. Yes, some two weeks later it is about half gone. Woe is me. I look like I've been caught by a jealous husband and then got the tar beat outta me. (Don't I wish) Do too! danceAgrin
The new pumps they sell for the 216 don't work without modification. The flange is too thick for the stock bolt and they are taller so the fuel lines don't match up. At least that's been my experience.
Charlie, Hope your black eye heals soon. You might elicit more sympathy if you post a selfie!
Charlie post a selfie? I would pay to see that!
Based on what I am reading in multiple classic vehicle forums and social media there is no such things as a good new fuel pump these days. You are lucky to get one that works out of the box and then don't expect it to last very long.
The best solution appears to be rebuilt original fuel pump.
