Posts: 165 |
Just started reassembly, is there a color the gas tank gets painted? Don't want to put it in un protected. Any sources of information on color of other misc parts as well?
Thanks in advance
Ron
Posts: 30,137 Likes: 95
Posts: 30,137 Likes: 95 |
I am 99% sure the gas tanks were not painted. They were made from a rust proof steel.
Posts: 19,484 Likes: 34
Posts: 19,484 Likes: 34 |
The gas tank was made from zinc plated steel much the same as the steel used in modern steel bodies.
Posts: 3,522 Likes: 49
Posts: 3,522 Likes: 49 |
If you are using a replacement or reproduction fuel tank I would contact the source to determine if it needs any additional exterior protection.
Posts: 165 |
it is an aftermarket tank I purchased 25+ years ago. I'll look into it further.
Topics58,057
Posts422,676
Members17,898
