Hello All,
So in addition to rebuilding my carburetor, I am also replacing the entire fuel system, From the fill ports forward.
My question is: should I replace the original bent metal tubing, with a direct replacement, or with fuel hose? Obviously fuel hose would be both cheaper and easier to run, but will it effect performance?
Has anyone here ever done this or seen it done?
As usual any advice is greatly appreciated.
Thank you
