#478498 02/04/23 01:41 PM
Restoring my truck and would like to put the original shocks on , which I have. This truck was a basket case , So I have no idea how they mount and the hardware need for them. If anyone has any pic's or some information on this , it would be a great help.
tom cirjak
Take a look at page 31 of the 1937 Shop Manual. That shows the operation of the single acting lever arm shocks. They mount to the frame through reinforced holes. The bolts are 1/2" coarse thread. I cannot remember the length.
Expect any used shock to need to be rebuilt. The packing type seal gets hard over time and wears on the shaft. So the shaft needs to be resurfaced and new seals installed. The last time I checked Apple Hydraulics charged about $200 each to rebuild them If they sell you a complete rebuilt shock it is about $300.
Plus you will need the links, pins, and bushings to connect the lever arms to the front and rear axles. Check Chev of the 40's online catalog to see those parts.
I put on a set of lever arm shocks on my 36 GMC and it was dramatic difference in the ride quality. Apple rebuilt my shocks 10 years ago and no problems at all.
1936 GMC T-14 low cab. TA for 1935-37 GMC, Director of the Gulf Coast Region
Thank you !
tom cirjak
Do you need pictures of the mounting brackets? I can send you some
Yes that would be great , Thank you ! Tom
tom cirjak
hello , if you do have pictures of the shock connections, that would be great. Please send them to
tomreo@aol.com Thanl you
tom cirjak
He may not be following this thread any longer. I'd recommend you send him a Private Message. Click his name then click Private Message from the drop down menu.
