Forget about it.
The connector is a bayonet type push in and twist with a fuse in it.
Just relacing the vibrator may or may not work. The buffer condensor has to be re0laced when putting in a working vibrator.
Dick is correct. The model number desinates 42-47.C46means 46.
Control in chrome is a dimmer for bulb when the headlight switch is activated.
VMB is a tone swich Voice Music Bass.
Mybe a riend with some experience can help and even then only AM. It will play without two of the rods under the push buttons only you will not be able to save stations with those.
I could go on but I won't.
