Posts: 17 Likes: 1
Posts: 17 Likes: 1 |
Hello, Would Like to know what type of Fluid should be used for the convertible top ?? Thanks..
Posts: 152 |
I have used ATF in mine and it works fine.
Is it dry now and you are topping it os or all new and empty?
Posts: 17 Likes: 1
There is transmission fluid in there now. If its better to remove the trans fluid, I will change it out and replace it.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Most low viscosity oil will work well. Hydraulic fluid, brake fluid, ATF are all okay.
