47fleet Offline OP
Hello ,
First post here, I searched so I apologize if this has-been asked before.
I have enherited my father's 1947, and I intend to finish it.
Right now I am working on the trunk, I have never seen the trunk latch and handle together I bought a replacement off ebay because the one my dad had was missing springs, and the pin.
I can't get the handle installed and I was hoping someone ight have a picture of the latch in their trunk to see if I have the right one or if there are any tricks on installing them.
Thank you,
John.
A little info on the handle and lock.
Do you have a key for your handle lock?
Russell #38868
'48 4 door Fleetline
47fleet Offline OP
I do have the key and the entire handle is assembled just not sure how to install it into the trunk. I can get it almost all the way in and I have been playing around with it but no luck yet.
Just a couple more questions.
Are you using the one you bought? Did you repair the original with parts from the one you bought? Have you compared the two side-by-side as to length and shape etc..
The one that fits a Fleetline two door is slightly different from the other models.
Their is no trick to installing, I think it has to be in the unlock position though. Don't remember for sure. If all is correct it should just slide all the way into the latch with the threads on the lock shaft sticking out to put a lock washer and nut on.
Russell #38868
47fleet Offline OP
Thank you the images they help, the two handles measure the same, and they look the same. Pin in the same location. I could have two of the wrong handles. As soon as I figure it out I will post some pictures.
Thank you for the information.
Took mine out to measure. This could be +/- a little.
Try this as it is how I got mine out and back in. Turn the key where the pin/pawl is sticking up/out (opposite from the picture) with the handle straight up and down. Leave it there. Now turn the handle sideways, pin at 9 and handle is at 3 o'clock. Push it in.
Looking into the latch from outside you should see a slot at 9 o'clock for the pin to go into.
Russell #38868
47fleet Offline OP
Thank you I will try this tomorrow during the day and let you know.
Oops, forgot to add, the latch must be in the up position and part the handle goes through must be sideways. Sorry!
Russell #38868
47fleet Offline OP
So good news and bad news, good news the handle is in, cleaned up some gunk and corrosion around the shaft and used a little gentle persuasion and it is in. Bad news, I am guessing the underside of your trunk looks much different from the picture below.
