I am replacing the steering wheel on my 1950 Chevy Styleline Deluxe. The horn wire that enters the steering column at the bottom is frayed. I would like to replace this wire while I have it apart. With the old steering wheel off, I cannot see where the wire attaches to the top of the column. All I can see is the steering shaft and the spring. I guess my question is: where and how does the horn wire attach to the top of the column by the horn? I have a new wire from the relay and when I ground the new wire the horn works. The only thing I would like to replace is the wire inside the steering column.
