#472962 08/10/22 10:48 AM
Pops36 Offline OP
Hi group
Does any one know if or where I can get a coil for my 1936 Chevy Master coup. It has the ignition wire coming out of it to the switch. I believe it is failing because when I reach 50/55 the engine cuts out, so I roll of the gas just a little and then back on and it picks up as if nothing happened. No popping back firing or any thing.
Thanks'
Pop's36
Pops36 #472967 08/10/22 11:05 AM
Does the engine mis-fire when it is running at the same engine speed in a lower gear?
Pops36 #472974 08/10/22 12:04 PM
Pops36 Offline OP
No, it accelerates strong with gas peddle to the floor between all gears and has zero issues until I reach 50 or 55 and then the motor just stops running. So I take my foot off the gas let slow a bit and then roll back into it and it picks right back up with no back fire or any thing.
Pops36 #472976 08/10/22 12:42 PM
Sounds like it’s running out of fuel, since you can let off and the fuel will have time to fill the carb. If you just go half throttle can you get it up to 55?
Pops36 #472977 08/10/22 01:20 PM
Pops36 Offline OP
yes, I was thinking vapor lock but it does it cold or hot. It is running on a electric fuel pump that is mounted in the engine compartment witch I have already replaced but doing some research I read that a electric fuel pump needs to push fuel not pull it and should be close to the fuel tank so I plan on relocating it back by the gas tank and running new rubber gas hose to see if that may help. Also think I my take it to a dyno to have it tested.
Pops36 #472983 08/10/22 02:45 PM
I agree with Dens41 that it seems like a fuel issue. Have you checked the float level in the carburetor?
If it was an ignition issue I think it would happen at the same higher rpm in any gear.
Pops36 #472989 08/10/22 03:48 PM
Pops36 Offline OP
Thanks for the info. I will report back after I move the fuel pump back by the tank and run new fuel line.
Pops36 #473002 08/10/22 06:55 PM
I’m not a ‘32 carb expert so this might not be relevant.
Some electric fuel pumps will produce more pressure than the float and needle valve assembly can handle. That can most likely cause flooding. Then when the system clears out there will be a low fuel event until the system catches up and floods again.
