#471665 07/04/22 05:29 PM
The driver side (right hand side in my case) window winder in my '39 Master is totally worn out, the spline has been badly damaged. Does anyone have information about where I might be able to source parts to repair this please?
Roddabaz #471669 07/04/22 06:03 PM
Mike Buller has done a great job in his thread explaining the process. Do a search under his name here on the Chat. Look for “1941-48 window regulator repair”. I tried to copy a link to it without success.
37Blue #471682 07/05/22 04:14 AM
Thanks, searched for the post and the name, 200 results on each search but no winder post in either ??
Roddabaz #471684 07/05/22 05:16 AM
Bill Masters
That's perfect Bill, thanks. I've looked at the parts referenced in the thread, but can't find the splined shaft that the winder fits onto, anyone know where to find one, if they are available? Otherwise I'm on the lookout for a complete regulator.
Roddabaz #471702 07/05/22 02:38 PM
Go to ebay, and put this in the search box: "1939 1940 Chevrolet window regulator repair kit". There are several.
Bill Masters
Just had a look as you suggested Bill, thanks for that. Have a pal who is visiting his daughter in Kansas soon, will see if she can order one for him to bring home for me. He's already arranged for a couple of parts to be there when he arrives.
Roddabaz #471704 07/05/22 02:51 PM
Good luck, Rod.
Bill Masters
1 member likes this: Roddabaz
Roddabaz #471768 07/07/22 05:04 PM
Ha ha ha. I have the same problem in reverse. My splines are OK but the handles are stripped.
PeterV #471801 07/08/22 02:30 PM
At least the handle is much easier to replace!
