#469994 05/21/22 12:07 PM
WSP530 Offline OP
1998 GMC Suburban 2500 with7.4. The starter made a bad grinding sound , never made that sound before,after a 3rd start it quit. I pulled the starter and discovered the tail end was broke off, the case was also cracked. There were no shims, the starter was a remanufactured ac delco. Most have a couple shims ,could this have been the problem?
1917 490, 1928 Depot Hack, 1925 Buick roadster, 1978 Vette pace car, 2002 Z06
WSP530 #470002 05/21/22 03:42 PM
The use of the shims varied based on how far the gear on the starter drive would engage the flywheel. The shims were there to compensate for manufacturing tolerances.
