#469443 05/01/22 10:32 PM
Does anybody have a picture of the E-brake handle ratchet on a 1923 or 24? I have a handle but no ratchet under the handle that bolts to the transmission. Wondering if i can make one or if somebody may have a extra?
Thanks Rooster
Lou Offline
. Hi Rooster, Here's a photo of my 23 Sedanette. Unfortunately it was "Out standing in it's field" before I bought it so there are a few weeds blocking the view. Someone else may have a better photo.
Lou .
Thanks Lou, kinda hard to see but better picture than i could find! it looks like theres 2 bolts that hold the ratchet down. Kind of a L bracket maby?
Thanks Rooster
A couple more if needed, 1924
Thanks Dave! Thats what I needed! Looks like the bottom of my e-brake handle is reversed from yours. Mite be the wrong one or different year. I noticed also you have a speedo cable in the torque tube ball. Could a 1922 or earlier have a different place for the cable? Front wheel?
Thanks Rooster
These may help. Not sure on yours but I have heard of some speedos being driven by a gear on the front wheel.
They turned out a little out of focus. I can try again if needed
What book is that from Dave? I have the regular 490 and 27-28 repair manuls, but everything else I have is 30s and up.
Rooster
Rooster here are some pages from the parts manual. If you enlarge the picture they are very clear. The Ebrake on a '23 is different than a '24.
Stephen
Steve
rooster,
Same book as Stephen put up.
Ill look it all over. I wound up with several e-brake handles! The pictures and diagrams help alot! And now I another book to look for! Thanks guys! Im learning alot!
Rooster
I guess you know that a lot of parts for 1923-24 models are identical with parts for earlier models of 490. So if you have questions I suggest that you always check the "1916-1922 Model 490 Only"-forum. And put your posts on both forums.
When I check the Technical-Prewar forums I always check both.
I never really understood the idéa with a separate forum for model 490, when it was launched several yeras ago. Especially as the 1922 model, which I have, has some crucial parts that are identical with 1923-24 models, and of course differ from earlier models. For instance propeller shaft and -housing, ring&pinion gears and a different thrust bearing on one side in the differential.
Per-Åke Larsson
Thanks swedechev I have noticed alot of the same parts between the years. I think my trans is a early 490 and shifter a 23-24. And from above im looking for the parts book now. Im building a peroid speedster, it was a stalled project I bought with no information. Looks to have a rebuilt engine, trans, and rear from different years. So im trying to put the pieces together and figure out what was and wasnt done. I have read about your differential problems several times! Glad you got them sorted out.
Rooster
Anniversary Ad
More Info
Support The VCCA!
Enjoy the forum? Become a VCCA member! The World's Best Chevrolet Car Club!
VCCA Raffle Tickets
Support the VCCA Anniversary Meet
Member Photos
4th Annual Gulf Coast Region car show
Rear apron bolts
Rear apron bolts
by nhinchas, March 23
Pictures of the heap
by Leapin, February 1
1950 Styleline Wiring Acc block
by WI_Jeff, January 22
Who's Online Now
6 members (Rustoholic, Mike Deeter, Jonjet, chevy50jim, 41specialdeluxe, RLackey), 51 guests, and 35 robots.
Key: Admin, Global Mod, Mod
Newest Members
Hago, James_35_chevy, RandallBailey, Nicko970, Rick_Mann
17,517 Registered Users
Today's Birthdays
Alligator, Garbo, Jim V., kc1952
Forum Statistics
Forums67
Topics56,385
Posts413,573
Members17,517
Most Online1,133
Jan 22nd, 2020
