Posts: 87 Likes: 2
Posts: 87 Likes: 2 |
Hi, Needing to rebuild or replace my fuel pump for my 1933 1.5 ton truck. Currently it has it's original stock manual fuel pump. Thinking an electronic would ease a lot of worries – any suggestions on where to go or what to get?
Thanks for the help.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
No need for an electric fuel pump. Your original will work fine and for a long time if it is rebuilt using a diaphragm that is impervious to alcohol. Bob Marx at Marxparts in Wisconsin will rebuild your pump or perhaps sell you a kit so you can do it yourself. All my old Chevys are running on mechanical pumps.
1 member likes this:
Ed_Osier |
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
Yes, my '33, '37, and '48 are all running on original type mechanical pumps with no problems if they are in good shape. I started them all up last week after setting since November with out priming them, just choked them, pumped the foot feed and hit the starter.
Ed
Posts: 87 Likes: 2
Thank you both Mike and Ed. I do believe I just need a rebuild, possibly only a new diaphragm after looking closer at it.
Mike, I took a look at Marx Parts, looks like a kit is available. I appreciate the help.
Ed_Osier |
