#465787 01/18/22 09:43 PM
m006840 Offline OP
Today I removed the wiring harness from my car . When I opened up a fuse holder to see what size fuse was in it i found a length of what looks like coat hanger-NO FUSE. I have a new harness ordered as this one was way past it's useful life and I can't believe in the 6 years I drove this car I never had a problem.
m006840 #465788 01/18/22 09:59 PM
never know what you will find :) i have heard of bolts being used, only drawback is the next weakest link will fail since the fuse has been bypassed :o
glad you did not have any issues :) like duct tape clothes hangers have many uses, well the metals ones anywho
m006840 #465793 01/19/22 12:26 AM
On my ”˜37 Master coupe Uncle Jimmy had installed a very high amperage fuse. It was a 1” long piece of 1/4-20 threaded screw. It did fit the fuse holder very well.
m006840 #465822 01/19/22 08:50 PM
They all "work" until there is a short - then the wiring acts like a fuse. flush
1 member likes this: Ed_Osier
I knew a guy that blew a fuse at night and all he had was a 22 rifle bullet, fortunately he was not injured but it went off and ruined the fuse holder on the back of the light switch!
Ed
m006840 #465826 01/19/22 09:17 PM
Wow nobody mentioned the use of a small Meccano axle !
m006840 #465835 01/20/22 04:38 AM
I have seen 4" nails in cars and houses and the inner foil wrapping from a cigarette packet wrapped around the old fuse.
m006840 #465847 01/20/22 12:41 PM
Years ago I was having problems with a (non-GM) car constantly blowing the dash lights/tail lights circuit fuse. After replacing blown fuses several times I became so fed up I stuffed the fuse holder area with wadded tinfoil, and didn't care if I burnt the car up. When I touched the brake pedal smoke started pouring out the top of the steering column. I was happy - I'd finally found the problem. A new directional signal unit went in and the car rolled up another 70000 miles trouble-free!!
kaygee #465907 01/21/22 11:30 PM
Probably not the best trouble shooting procedure.
Only the bad wires let the smoke out
m006840 #466368 01/31/22 11:08 PM
Be sure to replace that coat hanger wire with the proper gauge of new coat hanger wire. Hey, if it aint broke, don't fix it.
35Mike #466389 02/01/22 10:41 AM
m006840 Offline OP
I was thinking that seeing I have a new complete wiring harness from Rhode Island Wiring I probably should use a new fuse.
m006840 #466392 02/01/22 11:34 AM
With all new wiring and following the instructions it is not likely to let out more smoke. With the rest of the wiring new a new fuse seems appropriate.
kaygee #467868 03/12/22 09:22 PM
Smoke testing is good for one time diagnostic testing. But the secret is to keep the smoke inside the wire.
1935 Master Deluxe Coach
m006840 #467875 03/13/22 08:46 AM
If you are going for the .22 round,fire it first !! It will be lighter then !!! Best of luck !!
