modiol Offline OP
I am looking for a piece, and I don't know what it is called. It looks like a small brass Cup that goes into the oil connector with a spring. It helps to connect the oiler to the rocker shaft, and should be 1/2 in diameter.
Any help would be appreciated.
1938 Chevrolet 216
Thank you
VCCA Member 51121
Take a look at page 14 of the Master Parts List 1929-1941. I think the part you are describing is in group 1.928 which is on page 34.
modiol Offline OP
That one says 5/8" diameter. The opening is only 1/2"
The one in the picture doesn't fit in the oil connector
VCCA Member 51121
modiol Offline OP
Oh my gosh... my friend put the part in backwards. We too it out and turned it around. It’s all back together. Please ignore my ignorance,
VCCA Member 51121
More like something learned. It is easy to get turned around in this life.
Ever onward! Dean
BTDT! (Been There Done That!)
Thanks for letting us know that you were able to resolve the problem.
Have a good holiday season.
