P: Foundry Casting Mark for Romeo Foundry Co, Port Huron. Source: a PM of Ken Kaufmann.
7: Kaufmann also lists P1, P2, .... P6. I guess there also was P7.
11 5 20: Casting date November 5 1920
967-4F: Cannot help you, But I am curious too.
1 28 20: Casting date January 28 1920
1A5267: The first number is the Plant Cod. ”1”, means Flint Michigan. Source: Another PM of Ken Kaufmann, from 2002. You can get the PM as pdf on the webb,
http://www.gregwapling.com/hotrod/chevrolet/1912-30chevroletproduction.pdf. A5267 is the serial number for a 490 assembled at the Flint Plant. According to Floyd Clymers ”Early Chevrolet history...”, published 1966, that number means that the car is a 1920 model. The serial numbers from Flint Plant this year starts with #92475 an ends with A20160. When a 490-Plant had reached serial number 99999, the serial number on next car started with the letter ”A”, so I guess the car got serial number ”A1”.
So I guess that your 490 is a 1920 model.
