#464070 11/30/21 11:54 PM
Avatar Offline OP
On top of the engine, between two valves is stamped a "P". Just under that is stamped "07". Just under that is stamped "11520". Anyone know what that means?? My car is a 1918 Chevrolet 490 Touring!! On the side of the block near the carburetor is stamped "967-4F". Just above that number is stamped "1 28-20". The number that's stamped on the ID tag under the dash is "1A5267". Any information would be greatly appreciated!! Thanks...Craig
Avatar #464141 12/03/21 11:47 AM
P: Foundry Casting Mark for Romeo Foundry Co, Port Huron. Source: a PM of Ken Kaufmann.
7: Kaufmann also lists P1, P2, .... P6. I guess there also was P7.
11 5 20: Casting date November 5 1920
967-4F: Cannot help you, But I am curious too.
1 28 20: Casting date January 28 1920
1A5267: The first number is the Plant Cod. ”1”, means Flint Michigan. Source: Another PM of Ken Kaufmann, from 2002. You can get the PM as pdf on the webb, http://www.gregwapling.com/hotrod/chevrolet/1912-30chevroletproduction.pdf. A5267 is the serial number for a 490 assembled at the Flint Plant. According to Floyd Clymers ”Early Chevrolet history...”, published 1966, that number means that the car is a 1920 model. The serial numbers from Flint Plant this year starts with #92475 an ends with A20160. When a 490-Plant had reached serial number 99999, the serial number on next car started with the letter ”A”, so I guess the car got serial number ”A1”.
So I guess that your 490 is a 1920 model.
Per-Åke Larsson
Avatar Offline OP
Thanks for the response swedechev!! I wonder why the car is titled as a 1918 model? The car seems to be in great condition with 5727 miles on the odometer...but who knows if that's accurate??
Avatar #464165 12/04/21 10:10 AM
My 1918 490 is titled as a 1916. Most states didn't issue titles until the mid 1930s or later. When issued they used various means to identify the year so inaccuracies abound.
Avatar #464169 12/04/21 12:32 PM
As you say, who knows. Or can you exclude that a former owner took the motor and the ID-tag from a 1920 model and put in his 1918?
The frames on 490 up to 1919 differs a little from the frames on 1920-1922. The easiest way to see the difference from outside the car is to compare the front fenders, and look close where the fenders meets boards. Distinct angel versus an S-shaped fender.
See examples on this website Mässing & Nickel (Brass & Nickel). First a 1919, owned by a friend of mine, after that my 1922
Per-Åke Larsson
Avatar Offline OP
That's great information! Looks like I have the S-shaped fenders on my car!!
Avatar #464435 12/11/21 04:29 AM
Lou Offline
967 is the casting number on 1918 - 1921 490s. The F may stand for FERRO casting company.
See web page <http://home.znet.com/c1937/Cast.htm> for other years.
Lou #464449 12/11/21 08:49 AM
Thanks Lou!
Per-Åke Larsson
Avatar #464547 12/14/21 02:28 AM
Avatar Offline OP
Thanks Lou! The engine is stamped "Ferro" on the side!!
Avatar #464681 12/16/21 08:34 PM
The 1920 490 frame has a large crossmember at the front pair of running board brackets, the 1919 and earlier have front and back running board brackets in a similar “L”. Shape.
JACK
