#462774 10/18/21 10:20 PM
DSVW Offline OP
Hi, I am looking at purchasing a 1956 Bel air 4 door.
It is pretty clean underneath but the majority of the floor braces appear to be rusted through.
Is that a structural concern?
How much am I looking at to have those replaced and welded in?
Is it a difficult job for a do it yourselfer who knows how to weld?
Or should I walk away?
Thanks.
Wilwood Engineering1955-1957
On that model the body supports help to rienforce the frame. They are available but will be expensive to replace.
I would RUN AWAY FROM THE CAR.
DSVW Offline OP
Is there a difference between the floor braces and body supports?
I think these are floor braces. They are small curved pieces that weld from the side of the car onto the floor pans. Are those structural and do they reinforce the frame?
Thanks.
Before you do anything more, if it is possible, take a small hammer and tap along the frame sides, especially in the area around the "kick-up" over the rear axle. If you feel/hear a solid "clunk" that would indicate the frame is solid. If it feels spongy when you tap it, or sounds like hitting plastic, or you punch a hole in the frame, I would do as Chev Nut suggests and RUN AWAY! My thinking is that if the body mounts are badly rotted, the frame is probably rotting from the inside out as well, so the car is not worth spending a lot of money to rebuild.
In short if the body supports are rusted Out there ae other parts thatAe thin or patched Etc.
Anniversary Ad
More Info
Support The VCCA!
Enjoy the forum? Become a VCCA member! The World's Best Chevrolet Car Club!
VCCA Raffle Tickets
Support the VCCA Anniversary Meet
Member Photos
4th Annual Gulf Coast Region car show
Rear apron bolts
Rear apron bolts
by nhinchas, March 23
Pictures of the heap
by Leapin, February 1
1950 Styleline Wiring Acc block
by WI_Jeff, January 22
Who's Online Now
10 members (Gordon21, Chev Nut, famoore1, Dave39MD, Pops36, roara, Hawkeye, CarDC, ruscar, gachap), 26 guests, and 27 robots.
Key: Admin, Global Mod, Mod
Newest Members
Lefthanddown, TAG, tbrissett68, Louiee, PFLCO
17,567 Registered Users
Today's Birthdays
beep38, IMFALCO, ironchris, touringman
Forum Statistics
Forums67
Topics56,642
Posts414,977
Members17,567
Most Online1,133
Jan 22nd, 2020
