cabboy Offline OP
I have looked and cannot find. Does anyone know of a source of 5/16" diameter felt wick to replace in starters and 1/4" for generators?
Thanks.
The felt wick in the 943-J generator was smaller in diameter than the felt wick used in the 714-L starter.
cabboy Offline OP
Didn't measure the wick in the generator as I was able to reuse them. Also wasn't paying attention. The generator is probably 1/4". Anyway anyone know of a source of either size is the question at hand.
I have also been looking for this. Some possibilities (that I have not verified yet) are:
http://www.magnetoparts.com/oil_cup.htm 1/8", 3/16", 1/4", and 3/8" in 2 inch lengths.
http://www.classicgenerator.com/ I just put an inquiry in here for an odd generator bushing and expect an answer soon. I believe he has felt wicks.
https://www.mcmaster.com/felt-wicking Look for "firm felt cords" Available in F1 and F3 felt. I think F1 is what we want in a generator, but would like to hear what other people think. Smallest length is 5 feet.
I did some research on the generator oil wick and the diameter of the generator oil wick is indeed 1/4" like you thought.
cabboy Offline OP
Thanks all for the info. I will research further.
So I take it that you put an oil soaked wick in the little flip top holes on the starter and generator. I did not know that. I was going to ask about that when I got to that point on my car. There were no wicks in them when I got the car so I had no idea what they were for. What kind of oil do you use? Is that all you do is soak a wick and put it in the hole? How long should the wick be?
cabboy Offline OP
I found them when taking apart my units. The generator has one at the commutator end only. It goes up into the hole and lies across the bottom of the void. It's 1/4" and wicks oil up to the shaft via a hole in the side of the bushing. If I remember it was about 1 1/2 to 1 3/4" long. No wick at the pulley end except for the felt washer that acts a seal for the shaft.
The starter has a felt way down in the hole below the oil cup and again there is a hole that allows the side of the wick to touch the armature end. It is 5/16" and maybe about 1" long. I believe regular engine oil is sufficient or maybe a lighter one. I haven't checked into that yet
On the end commutator end plate of the generator is a heart shaped cover with three 8-32x3/8" screws. If you remove that cover you will see the oil wick. Any type of light weight oil will be sufficient to use on the oil wick.
I bought a few feet of McMaster-Carr's round felt wicking in 1/4" diameter, and it worked fine. I have quite a bit left over and would be happy to send you a foot of it at no charge if you'll get me your mailing address.
Mark Yeamans
cabboy Offline OP
Originally Posted by Mark Yeamans
I bought a few feet of McMaster-Carr's round felt wicking in 1/4" diameter, and it worked fine. I have quite a bit left over and would be happy to send you a foot of it at no charge if you'll get me your mailing address. Hi Mark I will PM you,
Robin
Mark Yeamans
"Any type of light weight oil will be sufficient to use on the oil wick."
Like 'electric motor oil'? (I have a can of this from Sears. Its 'W' is not specified.) Or like 5W-20 motor oil? Is there any concern regarding the compatibility of modern oils with the metals (brass or bronze) possibly used in the 943J generator and the 714L starter?
Thank you.
wel2
I use air tool oil but any other type of light weight oil will work as well.
Thank you for the Welcome! And for the oil info. I'm a newbie just getting started on a '29, 1.5 ton truck. And I'm learning that I have a lot to learn.
Good luck with your project and if you have any other questions let us know.
you can buy Felt Wick from Woollen Textile Industries at http://www.wtifelt.com
