#457911 05/28/21 07:51 PM
I found this spring in the box with other parts for the 28 truck I am working on. Any ideas where it goes?
I really don't know about your model but on later models I've seen one like this that fastened to the torque tube and E-brake.
.....and others a similar spring hooked to the chassis and to the clutch arm at bellhousing.....Mind you I'm just guessing!!!
1937 Chevy 1/2 ton Pickup
1950 Chevy Styleline Deluxe Coupe
1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
That's the front brake return spring for a 1928 LP 1 ton truck.The small end hooks onto the front brake pull rod clevis,the large end simply hooks into a hole that's punched into the chassis.
CJP'S 29
CJP'S 29 Any pictures? The 28 1 ton is what I am working on. Thanks for any pictures
PM sent
CJP'S 29
Tom,the email address you gave me in your PM won't work.Check your PM's mate.
CJP'S 29
