Posts: 434 Likes: 1
Posts: 434 Likes: 1 |
I have a new gauge cluster that I am planning to install in my 1951 Suburban. The engine is a 1952 235, currently in the truck and running well. I've removed several temp gauge sensors in the past, but this one is acting like it doesn't want to come out without a struggle. I'm very wary of applying too much pressure with the wrench for fear of cracking it off. There is certainly some paint build-up on the threads, which I will remove, but I fear there may be rust, etc., also making extraction difficult.
I'm writing to ask if anyone might have good hints or advice about removing the sensor. I will certainly apply a solvent like PB Blaster. Would applying heat here be a strategy or advisable--besides ruining the engine paint in that area, will heat be effective on that much cast iron in that location?
Any hints or advice are greatly appreciated.
Thanks,
Jim
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
Sounds like someone WAY over tightened it. Since the maximum pressure it should ever see is about 12 psi it really does not have to be all that tight. You don't specify what type of wrench you are trying to use. I have found it is best to get in a position where you can use a good 12 point box end wrench. Other than that just be careful. If it acts like it is going to twist off then go ahead and use a little heat. Sometimes heating it up several times and spraying penetrant in between like some one else talked about works best.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
A method I have had success with is to gently tap the parts you want to separate with a light hammer while the PB is soaking in though you may need to tap and soak for a while. The bulb is held onto a tapered seat and over time corrosion is a very good glue. Tony
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I don’t understand how one can put a box end wrench over a sender that has a line coming out of it.
Mine was stuck like that too. I think soaking it with something might be helpful. I eventually pulled on mine expecting it to break and it came loose.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Use a tubing flare wrench.
That is different than a “box end wrench”. Anyway I gather the problem is not rotating the nut but dislodging the sender.
Posts: 434 Likes: 1
No, the problem IS rotating the nut; dislodging the sender might be a second problem, but for now, the problem is getting the nut that secures the sender to move. I fear that if I crank on the wrench to loosen it, it might break and leave me with a real mess. I can get an open-end wrench on it or a tubing flare wrench, but in either case, I want to make sure I get it loosened in one piece. That's why I inquired about heating up the cast, or other strategies. Thanks.
I would think that you don’t want to heat up the cast more that what the motor does. That is because it is a temperature sender filled with ether. Of course your flare wrench will give you the best chance of success.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I appreciate your cautious approach to this. I understand your concern. One key place to watch is where the tube comes through the nut. You do not want to start twisting the tube if the nut does start to turn. I agree with lots of penetrating oil and letting it soak.
I would also try to remove it when the engine is hot. Maybe even do 2 or 3 heat cycles after the penetrating oil soaks. The “remove it when hot” trick almost always works with oxygen sensors that you think will never come out.
And don’t forget the trick to make the first move one to tighten it. If you hear or feel a little “crack” you are on your way to success.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
First, are you trying to save it? If so then what the others have advised is about as good as it gets. If you are not trying to save it then use a suitable wrench (I'm thinking the "nut" is square) and use all the pressure necessary to loosen it. If it wrings of then simply use a drill and easy out. The reason I question whether you are trying to save it or not is because you mentioned a new cluster and I assume a new cluster comes with a new gage. Best and good luck with it. Charlie
Posts: 434 Likes: 1
Thanks for the good suggestions. The "remove it when hot trick" makes a lot of sense. No, I am not trying to save the sensor--I have a newly refurbished cluster with a new temp gauge; just trying to avoid having to resort to "a drill and easy out", as Charlie mentions.
I am not in a hurry on this, seeing that I won't be installing my new wiring harness and gauge cluster until I complete a few other tasks on the restoration. Just trying to prepare in advance for the replacement.
Thanks again,
Jim
